182 OE Intake Manifold Gasket Kit
Car  RS200
Can you kind folk point me in the right direction for a set of gaskets for the std intake manifold kit?
I will be removing mine and painting and want to put new gaskets on.
Thanks.
Ring Renault Wolverhampton and ask for parts.
I paid about £8 ish delivered, I work in the trade though.
Worth asking for trade parts and explain you are on the forum
@Phil555
My ‘local’ dearer was around £14/15. I rang wolves and even with delivery it was less than £10 delivered, next day too iirc.
Worth a call tomo. There will be an option when you select parts, along the lines of if your after trade parts press hash.
Do that lol
Yeah but once it's squashed it seems like it would be better to replace it next time you replace the inlet manifold (i.e in the same way a crush washer works)?
There is no mention of replacement in the Renault manual when removing the inlet manifold.
Just means you'll have a lighter wallet.
That's good to know, although I did end up buying a new inlet gasket anyway as it was about £5 so I thought it was worth doing
