182 passenger seat
The passenger seat in my Clio has suddenly stop letting ne roll it forward to access the back, is there any solution to this as it seems to be a common issue. Help appreciated
search around on the floor under the seat. There will be a small metal 'dowell' flanged on one end and probably covered in grease. It pushes through the sliding mechanism and works its way out over time. Check your drivers seat to find where to put it back.
I found mine stoped working when i adjusted the seat, i moved the backrest up and down a bit and it magically came back to life
I found a show under mine that got the laces tangled in the runners stopped mine, but of scissors and WD40 cured it, you might just need to grease the runners up.
Sorted, yep sure enough when i adjusted the back rest i heard a loud click and everything returned to normal...
