182 rear indicator bulb replacement
Car  BG Clio 182
How do i change the rear indicator bulbs?
Do I have to remove the torx screws holding the plastic panel in place and then unscrew the screw on the headlight and then remove the carpet?
No undo the black plastic screw, pull the light off the rear of the car, unclip the bulb holder (about 6 finger clips) and then reverse to fit.
Make sure the lugs on the light are located upon re-fitting.
Right got the light out no problems.
How do I get the white thing with the wires off the back of the bulb?
There are about 6 clips holding it on around the edge. Bit fiddly and hard to undo but it will come off
It's a plug. There's a tab at the bottom of the plug which you can depress with your thumb. You need to wiggle the plug out as its a tight fit.
