182 STOP light on dash - HELP !!
MarcB
Car  Vw Golf
Yet Again another problem with the Trophy.
After going through all the oil level stuff and me buying a oil level sensor (getting fitted on tues)
This light now comes up on the car when i start it in the morning. After about 3/4 mins it goes off and does not come back on untill the next again morning.
I have seen a topic on here (As Below)
http://www.cliosport.net/forum/showthread.php?494516-Stop-Light-and-Oil-Light-Up
After reading the topic above im now going to change the oil pressure sensor (8200671286 - £15.28+VAT) on tues with the oil level sensor.
Here is a picture of what comes on when the car has just started. If the new oil level sensor and the oil pressure sensor that i fit on tues dont repair the problem im then getting the oil pressure checked to see if its all above board.
All comments and help wlecome
Changing the following parts to try and sort this
1, Oil level sensor
2, Oil pressure switch
and while im in there also doing the knock sensor above the oil filter
