182 sunvisors
Car  Mercedes C Class Sport
I just bought a pair of 182 sunvisors from giles, and went to fit them and there are no wires to connect to...Can anyone tell me what i need to do?
I have a 51 plate dynamique +
cheers
Gaz
You need to run two wires from each visor to the central courtesy light.
There is two +ve feeds at the light and a -ve. Make sure you connect the visors onto the +ve feed that is permanently live, ie not just when the doors are opened! ;)
You'll need to get some mate as they aren't pre-wired on the lesser spec'd cars.
Will take 30 mins max.
Also get some bullet connectors for the plugs on the visors ;)
Yeah i remember Daz did it too!
Are they easy to connect to the central courtesy light?!
thanks
Indeed I did Giles, a nice subtle touch and the women loved it! lol! ;)
for cosmetic reasons obviously :rasp:
Gaz, you just need some of those splice-on connector blocks ,the blue ones that all good car shops sell :)
Just when you open the visor, they have a switch arrangement inside them that activates the light when you open the mirror 'cover' :)
will i need to take the roof lining off then? thanks
nah not really, just put the wires though the hole.
I would take the door lights out/cover, take two old sunvisors out and unscrew the clips. May need pull the rubber from the sunroof.
