182 Using Coolant
  Audi TT 3.2 V6
Is this fairly normal? My expansion tank has gone from just under full when i got the car in Feb to just above empty now.
Am i ok just to top such a small amount up with water or do i need to use proper coolant from Renault?
Thanks, Russ
  Clio 182 :)
I think you need to stop drinking it :lolup:
Seriously, get some at a local car shop, (or Renault if you want to), but do not replace it by water ! ! !
IMO, water is just an emergency solution ;)
  Audi TT 3.2 V6
But it tastes so good :( lol
I'll go get some tommorow. I just read somewere that you can only use Type D coolant or something?
  Clio 182 :)
I think you're right... Type D iirc...
Best thing to do : ask your local renault dealer, and then go somewhere else to buy the coolant :)
  Audi TT 3.2 V6
Lol Like it.
Well directly across the road from my Renault dealer is....a GSF!
That'll do nicely i think...pretty good idea of GSF to set up there imo after people have been into Renault and been given an astronomical price for a washer or something.
  Recaro'd 182
go to gsf much cheaper, i asked for a 5l+ 2L container and he only had the 2l ones which came up as 1l ones at the till so i took 4 at half the price!
  ITB'd MK1
for that small amount water will be totally fine for a top up, just be aware that you can't top it up with water every time it needs it or the concentration will drop.
  Clio 182
Hi Guys - I need to do a coolant change. Do u have a link to the type d coolant from GSF you mentioned above as i can't find this on their website.
Can you confirm how much i need to get to do a complete coolant change
Rob
Rob
5 liters from memory but do a search ive written it before
