197 cams or catcams 421
yeecup
  mk8Fiesta ST,172 cup
I already have a set of 197 cams ready to go in my cup to be timed at 8 degrees on inlet using the tool, question is would 421s be better or would the difference be minimal, also going to run on standard ecu. cheers.
JamesBryan
Decent enough gains from 197 cams tbh.
421's need aftermarket ecu to run well, 438's are similar but can be timed using oem tool and run on stock ecu with a remap.
