19Dci help please
Car  172
Need some advice I'm running a megane scenic dci been running fine nipped into shop wont start had to get recovered.
I have worked out its down to fuel, The lines into the fuel pump are clear and you can usually hear see them being primed when you turn ignition on now its doing nothing. Bit of googling and they have a low pressure fuel pump which are located between chassis rail and engine and pretty much inaccessible
however i managed to confirm its getting power and does nothing when u put a direct feed to it. Likely problem?
If it sounds like the cause next job is to get the thing off which sounds like no easy task
