2.0 brakes on a 1.2
  1.2 16valve sport
What would i need to fit 172/182 brakes to a 1.2
Would it make it eaiser if i also bought 2.0 coilvers as im getting coilovers either way/ e.g upgrade to 2.0 coiles and brakes at the same time
  182, SQ7, Trafic
Lol!
Your going to need hubs/driveshafts/steering rack/wishbones to convert it I think!
Da
  Less
Personally, unless you're doing the 2.0 engine conversion, I really wouldn't bother.
  Astra 1.9Cdti SRi
you can do it, but you need a bracket to be made up,
its easier to either buy williams/valver 4pots, or the big brake kit from k-tec,
  BG 182 FF
if you want to get bigger brakes and not pay silly amount like you would be if you want the brakes of a sport. Why dont you get some off a 406 coupe, the brembo ones, iirc they more or less bolt straight on :)
  Astra 1.9Cdti SRi
big brake kit would be easyier than messing about
http://www.k-tecracing.com/show_product.asp?id=568
same size as sports aswell i think?
The only difference between this and a normal 1.2 brakes are...... 285mm discs THATS ALL,
Its the same caliper carrier just been modified a little, something you could do yourself,
i have it and i was shocked tbh, as id though you would get bigger caliper's and all, but i was wrong, Also It doesnt fit under 15's :( so mine are yet to go on until i find some 16's
