Quote: Originally posted by psychy on 28 October 2003
if i connect both +ve & both -ve from subs into one channel, would that not just draw power from just one channel? the other channel would be left unconnected??
how would that get max output from amp then?
im confused
and im doing my masters in Electonic Engineering!!
YES, MASTERS IN EE!!!
I think i have to leave the union bar a few hours early form now on.
Yes this is true, you can not run a two channel amp at 2ohms with two 4 ohm subs, that is why you buy a mono channel amp for subs as you can run both subs off the one channel and get it at 2 ohms. If you what to get the most out your amp you need to buy another two 4 ohm subs and have 2 subs on each channel, or buy two 2ohm or dual 4 ohm subs and run one of each channel, or buy a mono channel amp.
What you want to do can not be done with the equipment you have
