2 problems
Nafoff
1. i am sure my trip computer keeps resetting itself, i am sure i am not pressing the reset button by the dials (not something you can really do by accident.
2. i can't seem to get the anti-hijack door locking to work, i have tried setting it, but t locks for a split second then unlocks again
any ideas on either would be great, or the way to set the anti-hijack would be good to just to check.
Ali
  V6, Trackhawk, GTS
1 - Battery.
Same problem i've got...But not changing the batt just for that!
  225 powered mk2
Are you on about making the doors lock when u turn the key in the ignition? i need to know how to do it aswel :)
  182, SQ7, Trafic
Mine also does this and only noticed it since I moved my battery to the rear of the car. But I hadn't linked the two until I saw this. Is quite annoying but then sometimes it doesn't do it.
My anti hijack thing still works though. I forget how its done. Is it ignition on, hold for 5 seconds, ignition of, ignition on?
Nafoff
dj - do you think you could be accidentally earthing somewhere in your connection now its moved to the rear....
i was thinking if it was the battery or the alternator not giving it charge the performance mods i can gain from this
Alastair.
  986'S 172ph1+182FF
anti hijak shiz is just hold the button down for 5 secs until it beeps, same to reset it, locks ur doors/boot after 5 secs
Nafoff
looks like i may go jap then......and possibly relocate to the boot, i am guessing though it would be loosing charge due to the alternator?
if thats the case i may need to look into a new one of those.
  f**ked ph1 172
my ph1 does it too, annoying as f**k as i have to manually work out mpg.
batteries just have a working life of about 3years. as they dont like the cold or the hot or constant changes in temp.
If ou kept your battery at 20deg c constantly it would probably last 6-7years!
  182, SQ7, Trafic
I don't fancy getting another battery yet as made the box to suit lol! So hopefully its fine!
It shouldn't be earthing anyway it isn't from the + as nothing would work and fuse would of blown surely :s
  BMW E46 330i Touring
Well, as per my thread mate - I've just changed the battery and it still does it. :(
As for the locking situation, I've had a variety of odd electrical based goings-ons, but they all sort themselves out when I turn the car off and start her up again.
Tis really annoying me, especially since it looks like I shelled out for a battery for no reason.
Nafoff
well i got a new battery.........
and its still resetting the trip computer every bloody journey, its dam annoying... going out to mess with the car today, may disconnect the battery again and try resetting everything..
does anyone know how to set the anti-hijack then?
You've cursed mine, it's done it a few times this week... I've also had a new development in intermittent indicators! That's fun when trying to get into my road.
You turn the anti hijack off and on by holding the button down until you hear a beep.
Marky_
1. I could have just been the weather. Mine seems to reset after particularly cold nights.
Still shouldn't do it though. Mine did it every time I started the car from 'cold', so I replace the battery and now it does it occasionally. I'm attributing this to UCH problems...
Nafoff
read up about the anti - hijack whilst i was out working on the car, have turned it off, and now turned it back on again... hopefully this should help
  Megane
I had a similar problem with the start, changed the battery and was fine for about a month, before it re-ocurred....
Its now getting a new earthstrap from the battery to the shell/chassis, due to excess corrosion within the cable.
You could try that next...
Nafoff
well both these problems are still happening....
i have tried various with the trip computer and even after a battery change it still happens..
as for the anti-hijack, well that seems confused as hell
i tried setting it and it locked the car after about 8 seconds, i wasn't even in the car (its meant to lock when you start driving at 4 mph....)
  172 Race Car
Dash is resetting due to the voltage dropping below a certain minimum needed to retain the memory.
As said this is often caused by a battery on its way out. Relocating it to the boot will not help as the voltage will have to travel further and you will have the same problem (I had this on mine.)
the only way I managed to stop mine doing it was to wait for the fuel pump to stop priming before cranking.
You could also have excessive current draw by your starter motor.
Make sure you are starting the car with everything switched off, ie interior fan/heated window etc
Nafoff
Turn your electics on presa and hold the lock button should bleep
lol...how many times i have heard that...i have been doing that
brand new battery dude, it shouldn't really have an issue, i have noticed a few times that the car has struggled ever so slightly to start.. and i have been starting it with the stereo and the blowers working..will look into this
