2002 172 gearbox mount
Car  clio v6 vw golf r32
i think the gearbox mount as gone as car is knocking when changing gear ive found the one under gearbox that looks really worn as there is a lot of movement when i rock engine is there anymore to check and where can you get these from apart from dealers thanks
also check the upper gearbox mount its under the battery, they do come loose you can get replacement mounts from k-tec racing, but i would go with the renault ones the part no for the lower gearbox mount is 7700795688 hope this helps
i done the 4 mounts on tuesday on my car, part numbers and prices at trade price....
6000073669 - £50.60 - Engine mtg c2
8200103802 - £28.11 - Support
7700795688 - £26.08 - Mounting LH CL
8200089697 - £19.78 - Plug
Hi there, I had this, for me it was the gearbox lower mount, bit of a gotcha, because it is the mount under the battery, but it tightens from both ends. Mine wwas the lower nut that came loose. Took me ages to work it out, because the top part of it was still tight! Hope this helps, Joe
