2006 clio 1.6 cambelt change
Car  Sunflower Yellow Ph1 172
anyone any ideas on how much the cambelt change will be on a 2006 clio 1.6 dynamique s. renault have quoted £539 which seems steep even compared to my old 172. preferably need somewhere to change it near to birmingham.
it's a bit of a prick to do. The water pump MUST be changed, and to remove this the entire aux setup needs unbolting. Think we charge about £430 with gen bits
Based in Nottingham and £380 here also using Renault parts. Fred is closer to you though so give him a call cos he loves the K4M's :rasp:
Mick
We charge £399 (may even be 349) all in, main dealer, easy job, did one the other day.
No without water pump, never find they need replacing, most of the cambelts we do 9/10 the car has only done 30-40k so they are fine, no leaks, bearing ok etc. Renault do say that a slight bit of crusty residue is acceptable and wont need changing. If it looks like a christmas tree then yes they get replaced.
Havent done a pump on a clio3 k4m iirc
I might review my policy on those then. Would be easier. Still dont trust a k4m pump though
Ash, yes my price also includes for a waterpump but on a Clio III it may not need it (as above) and in that case it becomes cheaper by -£56. Does include the Aux Belt kit though
Mick
yeah i have never done one yet on a clio 3 water pump i cant wait by the sounds of it. do you know about changeing the shim around on the idler too?
Yep, its the same on the R26/27... comes as part of the kit if you get the right parts manager ;)
I always price to replace them though as my prices are pretty much based on engine platform rather than vehicle and on a 30-40k vehicle the water pump should be fine and so its owners choice to have it replaced or not (though for the cost vs piece of mind I still try to press for a new unit being installed cos it takes an extra 15-20mins). On 100k Megane I's though they get done religously
Cant say iv done a clio 3 k4m water pump either. But as ali says, most we get is 30- 40k cars so they are genrely sound.
