No and their isn't one.
The actual box speed is hardly any different on the 220, it's the actual paddles and the speed that makes the difference.
Nothing wrong with the 200.
There is no Trophy update for the 200, there is only AN update that improves changes in auto mode.
If you're looking to make a 200 feel like a 220 you've no chance.
Renault, it was a software update that could be done during a serviceDon't know where you got that idea from? AN update to improve gear change logic/ratios in Auto would be great as this is one of the little issues I have with the 200T compared to the Trophy. Where is this available?
Early 200s can have the gearbox software updated as I had it done on my old 13 plate EDC. Renault did it.
Ah fantastic. How did you go about getting it done? Ring my closer dealer?
Speak to the service department about the software upgrade to book it in, there are some nominated Renaultsport branches throughout England amongst the regular ones. Some dealers won't be aware of it
No problem, be interesting to see what they say.Awesome, will get on to them soon. Thanks for the help.
Yes its a software update to the box. Makes changes a bit quicker as per the trophy thats they only thing they changed really.
I'm in a dealer in Bristol if you want it done
I’m up in Leeds so would probably go to a dealer nearer if possible. If you have an idea of the price and if I can get it done without the service that would be appreciated. Cheers.
Check with Paul at RST - I think he can load the update
A map then 😅i'm going there for a stage 1 in a few months.
A map then 😅
How much did they charge you for it?Early 200s can have the gearbox software updated as I had it done on my old 13 plate EDC. Renault did it.
this is not the case, The box software was re calibrated to make it shift gear 50% faster, the paddle change was all about feel, not shift speed.The map doesn't make it trophy quick, I don't understand where people are getting this from, it improves auto mode.
The changes are the same speed it's the actual paddles that make the changes quicker in a trophy.
Is yours a euro5 as well? What did you say to the dealer to get the clutch set point recalibrated? I’m guessing that’s what people mean when they say an update.my renault said if you need an update they send a letter out. all euro 6 200t have same engine and gearbox software as the trophy but engine map is different ive tried to see if i can get the 220t rev limit and overboost functions put on a 200t euro 6 especially with have same turbo as the trophy. think all euro6 clio rs have the trophy paddles and gear change software. i know you can get the clutch set point recalibrated which can make the clutch respond better as that is what ive had done to my 200t.
Yeah, we can take a look in to it for you if you like Daz? Renault seems to have caved a little now and are letting some Independents with legit CLIP and ASOS access perform updates. They pulled it from us (I know Kev at Armstrongs was another effected), along with some other services, without any warning or justification.
