2118's on order !!!!
Car  ITB'd 182...
just orderd them from tweeks. cant wait to get them. coilovers next.
i drive a ff 182 with cup suspension. can i get fk coilies or do i have to get GAZ or H&R because of the 60mm hub bolt spacing??
help would be appreciated:)
make sure you've ordered the correct offset, as tweeks have a habit of thinking 182's use the same offset as 172's
must be ET43, NOT the ET38
Palmer motorsport i believe.
got it in one.
the ET43 was comissioned by palmer sport for thier clio's. The wheel was beefed up and is a stronger item.
And i was told that by Chris Jordan @ Speedline (before anyone claims its BS)
i have been running the 2118 ET38 wheels on my clio 182 lowered on LEDA's and not had any problems.
(mat got there first but i had it comfirmed by David Williams at Speedline UK)
The ET43 wheel is a high duty specification, stronger and heaver than the et38 version and was ordered for the palmer sport clio cups, cost £105 per wheel delivered next day ;)
go for h&r suspension or the adjustible GAZ set up - http://www.k-tecracing.com/show_product.asp?id=1776
i paid £400 all in delivered for a set of the palmersport ones, but that was direct from speedline.
Nope i presume it will become marks new project car as i need a car here for when i come back at 3 month intervals whilst awaiting my visa
yeah i have ordered et43. did a bit of research before hand. read that if i have clearence issuses once dropped on coilies to use a 5mm spacer which would then be et38???
anyway cant wait to get them but will need the coilies on to look good imho :cool:
and 2118's are?
the cars that made me decide i want them
^^ that is like a mirror image of mine now! almost identical, but the ring sticker is on the other side. (and it's a bit cleaner too)
Does anyone think these will look ok in white on a cyclone blue dynamique? I have considered them but dont want to purchase in case they look wrong.
just less than £105 including vat and del each
how?where from?
as said above i contacted a wheel supplier in my area that put me through to speedline corse and they quoted me £117.50 oer wheel. Is this probably because the middle man has added some on?
for a 1.2 mk2 ph2 expression should i go for et38 or 42?
ive been advised 38 previously
thanks
