2nd gear in 172mk 2
Car  Golf 1.4 TSI
whats the max speed yours gos to in second, mine is just under 60mph which is surprising, will only just go over 60 by the time i am changing gear, or hit the rev limiter
This is where the R Sport ECU helps lots, I used to hit the limiter all the time. The limiter is just too low standard, I dont thrash it all the way to 7800 now but it just gives you a bit of breathing space when your pushing on round 2nd gear corners etc.
It should definately hit over 60mph in 2nd mate...
2nd Gear = 8.7mph per 1000rpm = 63mph @ limiter
About 63>4 with the engine fully warmed up.If the engine is cold it will limit at 6500 and the variable valve timing does not operate.fully Warm=80c>
