3 speed Auto transmission query
Car  Clio 1.4 RT 1993
I have a 1995 M Reg 1.4 RT clio with 3 speed auto transmission and I want to change the oil which I understand is a simple process compared to the 4 speed model, which requires specialist tools. The Renault service manual makes an oblique reference to replacing an "M type" filter for the 3 speed auto but is not shown in the owners manual. The Haynes manual also has no information on the 3 speed auto - only the 4 speed, so I am wondering if anyone can confirm whether or not the 3 speed has an integral filter and if so where is it located?
I'll need your vehicle type code and gearbox code matey to be able to look it up. Drop me a PM
Mick
Many thanks Mick. I apologise for the delay in replying but I had to wait for my daughter to return the car today to enable me to get the info you require. The only numbers I can find are on the ID plate as follows:-
Chassis no - VF 1b57B 0112644506
Vehicle symbol - B57B
Reg no - M354 LDV (Not on the plate)
I do not know the gearbox code but there is a sticker on a small box attached to the gear box housing with the following info :- 641865EF
Refrigidor ( or similar word)
I don't know if any of the above is of any use but if you can recognise the auto gearbox from it, I would be much obliged if you could let me know whether it has an "M" type filter or not and if so, roughly how much they are?
Okay, the 3 speed MB1 box does indeed have a strainer which needs to be replaced as per the AD4 4 speed unit. Remove the sump (after draining off the oil of course) and you should see it.It says to replace the seal at the sametime also.
Mick
