36k is 5k away!
Car  182
Hi all! due to have my 36k service when i get there, dont know when as i do little then a lot of miles!!
Should i be getting the aux and cambelt changed on the 36k mark??? or is it just a normal service?
thanx all and merry christmas!
You need to change the AUX belt any way.
If you can afford the CAM belt change it, but its not cheap at Renault.
Does anyone have any idea how much the 36k service costs. Not taking it to Renault so as anyone taken theirs to a independent garage?.
Mines just gone over the 36k mark and the last service was over 13k ago now so it need doing soon.
Also my exhaust seem to be leaking at the first joint a bit, hopefully its just a loose joint and can be fixed easily and cheaply but if I do need a new exhaust how much are they.?
Thanks…
Thanks…
renault zorst are junk mate. gte somit else on it
Thanks…
Depends where your from, and I paid £200 at Renault Dealer for 36k service inc AUX belt.
That’s not that bad, the thing is my closest Renault dealer quoted me £245 for a standard service. So F knows how much a 36k one would cost me there. £200 doesn’t sound bad I will need to have shop around hopefully can get a similar price to that.
As for the exhaust I was under the impression that standard ones aren’t that much cheaper that decent stainless ones anyway. So if I do need one I will probably get a decent stainless one.
just had 36k service, cambelt, aux belt and power steering sensor done for under 550 at a very reputable garage down here
and yeah renault exhausts are gash!!! get something else on it
my 172 has 14k on the clock on a 02 plate. when should i next have a big service job? ie both belts or just one?
