3rd time lucky posting Help please
Ok I am strugling to come to terms with the new forum LOL
I bought some new front components and need some advice
bought these are recomended by msa182
http://caraudiosecurity.com/shop/product/products_id/1205.html
They will replace the door speakers and dash tweeters in my current setup which is as follows :-
Rears - Infinity Kapa 9x9's
Front - Door 2 Way Pioneers, Dash standard tweeters
Car is a 2004 Clio
Stereo is a Sony CDX F7500
I understand that the corssover supplied with the new speaker components seperated the sound out to high and low freqs for the different components.
My 1st question is does the clio already have a crossover build in to seperate between the standard doot speakers and dash tweeters?
If not which colours of wires do i need to connect to the crossover to install the new speakers?
Also can anyone point me in the direction of advice on gettin into the dash tweeters.
Thanks in advance and fingers crossed that I don't lose this again
Dave
Anyone? I know this is a long winded problem. I am sure there used to be some guideds to wiring and getting the dash off even the links to these would be great. I don't think everything has quote been migrated yet as I can't find anything searching.
D
well when im guna replace the front ones im going to re wire it ,
to get the dash out its pritty simple
pull off the 2 widow pillars , pull out half a inch then push the clip in with a screw driver
take out the 3 screws, on the air vents for front windscreen
the surround that covers yer steering colum, top bit push`s up
then u see 2 screws remove them
then pull the 2 silver strips that run infront of dash
then take out the 4 screws
then at either end of the dash is 1 plastic screw and plug take these out
then pull the dash out
the std renault ones dont have a crossover which is part of the reason why they are pretty sh1t
u will need to find somewhere to hide it behind the dash or sommat
