172 Cup
Just incase you missed one!!
Recall: 2 of 5
Recall Ref: R1999/026
Exact Model: .
Description: LOSS OF BRAKE SERVO ASSISTANCE
VIN: VARIOUS
Build Date: Various
Numbers: 18190
Defect: The brake vacuum pump fitted to the F8Q diesel engine can leak, with the potential to allow oil to enter the brake servo, with the consequence that a sudden loss of servo assistance and reduction of braking efficiency could occur.
Action: All potentially affected vehicles will be recalled, and the make of the vacuum pump checked. Should this be found to be of Magnetti Marelli manufacture, the pump will be changed for a quality assured unit. In addition, the servo and associated vacuum pipe will be examined for oil ingress, and replaced where necessary.
Launch Date: 23 June 1999
Recall: 3 of 5
Recall Ref: R1999/109
Exact Model: Laguna, Safrane, Trafic, Clio, Kangoo and Extra
Description: POSSIBILITY OF LOSS OF BRAKE SERVO ASSISTANCE
VIN: VARIOUS
Build Date: January 1998 to November 1999
Numbers: 29000
Defect: There is a possibility that the brake servo valve may not function correctly, resulting in loss of servo assistance to the braking system.
Action: Recall affected vehicles for the inspection and possible replacement of the brake servo valve.
Launch Date: 21 February 2000
Recall: 4 of 5
Recall Ref: R2001/084
Exact Model: Clio
Description: ACCELERATOR CABLE CONCERN
VIN: VARIOUS
Build Date: 1st January 1998 to 28th December 1999
Numbers: 10588
Defect: The accelerator cable may break and cause a sudden loss of engine power.
Action: Recall affected vehicles and fit a modified accelerator cable.
Launch Date: 24th August 2001
Recall: 5 of 5
Recall Ref: R2001/137
Exact Model: .
Description: PASSENGER AIR BAG SECURITY
VIN: .
Build Date: .
Numbers: 897
Defect: There is a possibility that one of the four securing bolts may be missing which could cause incorrect deployment of the air bag during operation.
Action: Recall affected vehicles and replace any missing air bag securing bolts.
Launch Date: 7th December 2001
