4 inch speakers - price point vs quality
Car  Clio 172, Jaguar XJR
I'm a little confused, im a bit of a noob to any kinda car audio stuff but I need a set of speakers for the front and rear of my project car.
The car is a dolomite sprint.
You can only fit 4 inch speakers in the front , 6.5 inch in the rear shelf.
I've got an excellent amp to drive it all but is it worth amping the front 4 inch speakers?
Anyway – price point wise the bottom two seem better rated ( RMS and Max Power ) than the Rockford Fosgate stuff.
What are you buying – what is the difference and would the RF stuff sound better.
If not – what do you chaps suggest.
Higher end
http://www.ebay.co.uk/itm/ROCKFORD-...2?pt=UK_In_Car_Technology&hash=item2c74fce59c
Mid Range ( ish)
http://www.ebay.co.uk/itm/Fli-FI4-4...7?pt=UK_In_Car_Technology&hash=item3cce445639
http://www.caraudiodirect.co.uk/speakers/full-range/4-inch-coax-10cm/alpine-spg-10c2
The Fli's look pretty good looking at the specs only problem is that with only them in you'd miss out on low end/ some of the mids :/
Provided you use plenty of sound deadening and such, any of those will come out roughly the same.
Your amp may be a big strong for any of these though, depending on how powerful it is.
concerns about mid-bass can be put aside with an underseat / behind the set sub
