406 Brembo's
406's are 4x108 bolt spacing and renault are 4x 100.
It's the caliper you're using, not the disc.
not if you want 310mm disks. Easy to get them re-drilled then you'll have MAN brakes
trouble is, your fronts will be so good, you'll start to need to think about rear upgrades which most dont worry with on clios. If you make the fronts too good without touching rears, you'll get excessive nose-diving
You'd need caliper brackets making then though to space it away from the hub 15mm. The standard Pug discs are 283 IIRC.
right re-read, I THINK that post means, with clio v6 calipers on a 172 hub you will need 310-315mm disks to make it work. E36 M3 discs would be worth looking at, ofset needs considering though, but spacers on the caliper would be ok :)
Something like that sounds good. I dont have disc's with 4stud pattern, only 5 stud (5x108).
Still for sale :D
