48 k service
Car  172
hay all cud sum 1 help me, im looking 4 the 48k service the list ov work that the garage should carry out, can any1 help
Oil and oil filter change using fully synthetic 5w-40 oil, cabin filter change and full car inspection and report
Check front and rear screen wash/wiper functions (including blade condition), also windscreen condition and rear view mirrors.
Check seat belt mountings and operation
Check all internal and external lights and horn
Test alarm/immobilizer (where fitted)
Anti-corrosion check-vehicle bodywork
Check condition of front brake pads and discs
Check condition of rear pads and discs/drums
Drain engine oil
Check condition and mounting of exhaust system
Check condition of gaiters and any play in ball joints, steering and drive shafts
Check for oil leaks and condition (including flexible hoses) of: Engine, gearbox, final drive, power steering (where fitted), hydraulic clutch (where fitted), cooling system, brake circuit (including pad wear warning light lads).
Check for leaks and condition of shock absorbers
Anti corrosion check of wheel arches, under body and subframes
Check tyre condition, pressure and tread depth
Torque tighten wheel bolts (if removed)
Replace sump plug washer
Replace oil filter
Fill engine with oil
Check/top up levels of: Front and rear screen washer bottles, power steering fluid, cooling system, brake fluid.
Check/top up levels of battery (except for sealed for life battery) and tighten terminals. Check charge level.
Check exhaust emissions
Check air conditioning drainage holes and condenser (where applicable)
Complete servicing booklet record section
