4th feels odd.
  172
Hi, recently i've noticed my 4th gear feels a bit .. strange.
It's hard to explain, the other gears click right in but 4th seems to 'drag' a bit. It goes in with no noises or anything and stays in fine but feels weird.
What could it be?
My clutch is fine and I make sure my foot is right down on gear change.
If i'm on a sprinted run and change it fast it feels more normal too?
Hope my box isn't messing up.
Check the gearbox chnage linkage is risgh then check your enough oil in the gearbox maybe renew then could be a damaged clutch starting to show or a worn engine mount
  172
What should I be looking at for the linkage?
Yeah i've thought about renewing the oil for a while now.
Is the mounts just a case of inspection?
