182 cup pack
Guys i need your help..I have a 1,4 16v clio(model 2000)with a lot of mods.The car was 98 hp and had 12,7 kg torgue and now is 140hp and has 17 kg torgue.
I have found a compressor kit for clios 1,4 and 1,6 16v.It has totally everything that might be needed as compressor,lubrication system,intercooler,extra ecu managment,adaptor and with a few words is ready to be pluged.It costs 5000 E with all the mechanic work.I was told that the power of my clio will go at 200-210 hp and the torgue above 24kg!!!!!
In case that i order one should also I change the pistons with forged and what else should I do in order not to have problems with the reliability???
The second is the 4 throttle system.I like naturally aspirated motors BUT nowhere can i find a 4 throttle system for my car.So if i decide that i want this way for lifting up the horses of my clio i should experiment a lot...Which of these two would you choose and of course why,and
is the compressor kit at good price??
Keep in mind that with little less money(4500)I can install a light turbo kit 0,6-0,7 bar but i dont like it.....even if the power output will be more.
Thank you and cheers from beautiful Greece...
