78k miles service
Car  Ph2 172 (black bean)
Having just recently got my 172 it needs a service. Now I knew this would be the case when I got the car but want to check what if anything special needs to be done. It's a 52 plate. Don't mind having to spend money but should I get the cam belt done or any other things that are known areas on the clio.
ye as said check belts being done, if its not been done then you will want them doing, also its probably new spark plug time, fresh coolant, brake fluid if it hasnt already been done, see one of the specialists on here, they will see you right.
if you've got the service book, it's all listed in there; although it's not laid out very clearly
the interval should either be 72k or 84k (12k intervals) - standard service + whatever's listed in the service book. it's a good idea to do the gear oil as well, which isn't listed
Got a mate doing the service tomorrow, cam belt, water pump, oil, plugs, leads, air con etc so pretty much the works.
