8 Injector Manifold
Trader Rating - 100%
1   0   0
  Evo
For use with one of these i believe...
Trader Rating - 0%
0   0   0
  ITB'd MK1
small injectors close to the valve is good for low speed atomisation giving better fine control at low rpm, injectors furthur from the port (can be adjusted for best results) works best at high RPM. if you look at F1 level stuff (a fairly extreme example), the injectors sit outside the trumpet
