94 clio plip help
Car  ph2 172
my sisters clio keeps leaking water onto the plip sensor and has decided to stop working altogether now, does anyone know how i go about replacing this, regarding reprogramming her key to a new sensor? thanks in advance.
you need to pull the reciever unit out see what sticker is on it and check the part number. if its a yellow sticker , you will have to order a plip with a reciever , if it a white sticker , you should be able to order just a reciever unit
which is approx £ 36 +vat. just fit it should work .
if you dont fix the leak will happen again , but just tape some plastic arond the end and dont push it right in and should be ok till you fix it.
