Hi all,
Bought a cheap 1.2 16v Expression for £200 that needs some serious work, i can do most of the work myself, just looking for some advice on the issues i have. Its on 102000 and we can assume it hasnt been looked after in the slightest
with no history at all.
1. Emissions Light On - Lambada Sensor.
2. Airbag & Serv light on - I've checked the connections under the seats, unplugged them cleaned the contacts and the lights still illuminate. The passenger site front seatbelt is tight and doesnt retract. Possibly have crash data in the Airbag ECU?.
3. Front Brakes - The brake pedal goes right down to the floor before the brakes bite and even then its really bad, had the front wheels off checked the disks & pads on the front and they dont look horrendus still some beef on the pads, no brake fluid leaks and the resovoir is full. Any ideas?
4. Handbrake - The handbrake is very very weak, when i mean weak i mean i can drive with it on and not notice anything. Cant see any handbrake cables dangling under the car, im assuming brake shoes need replacing because of milage?
5. Steering Colum creak & knock - The creaking from the steering colum is only when the car is warm and when turning the steering wheen side to side there is a clunking noise, also when braking occasionally the steering wheel shudders and theres a knocking sound consistant with the speed.
6. Rumbling Wheel Bearing - Theres a really bad rumbling from one of the wheels which i know is a wheel bearing failure but im having trouble figuring out which one it is, i assume its the drivers side rear as thats where i *think* the noise is coming from. I've had it jacked up and tried rocking the wheel side to side and theres no play in it although spinning the wheel there does seem to be a noise from the wheel but i cant tell if its the wheel bearing or not. Is there any other ways i can check it?
Sorry for the long post but can anyone give me some ideas?
