A pillar removal
Car  Renault clio 182
If theres already a thread then appologies,have seen alcantara trimmed covers. How do you remove plastic covers? How do you remove and correctly replace alarm sensors
I thought you meant cut the chassis :)
Do you mean the trim behind where the seatbelt attaches?
No sorry if i was vaque, the windscreen pillars that have the alarm sensors mounted to them
Oh, mine doesn't have alarm sensors, but you pull off the rubber trim, then they literally just pop off if you pull them hard enough, you have to lift them up because they are attached to the dash.
Hi,
If you have alarm sensors and dont want to fiddle with cutting the wire and fixing back together then just use a stanley knofe and cut from the top of the pillar to were the sensor is then you can slide the wire away
Then atatch the amazing new trimmed ones back in place
Austin
