A rare problem with clios! (sarcasm)
  Z34 370z Nismo
Im a bit baffled, there's alot of water in all 4 footwells the sunroof is leaking something terrible as it is, but its just soaked my roof. I can't understand how its getting into all 4 footholes? Ive got news paper down to soak up what I can but I can't find out what it is :/. Any ideas or no what it is?
  182 Trophy
It tracks down the A-pillars.
Usually, you need to pull the sunroof unit out (16 bolts you can access under the headlining by removing the interior light unit and seal around headlining under sunroof) clean up the area between sunroof and bodywork and seal it back up on replacement with a bead of silicone or similar.
  182 Trophy
Probably. If it leaks, you need to fix it. You'll soon find out if that stops the water in the foot wells.
Fwiw, I have a 1.2 Clio with Sunroof I bought to sell on. That had water in both front foot wells from the sunroof.
