So on the 182 we haven't had any abs for years, front excitor rings were different to rears when the engine was converted so got used to no abs feel of brakes, actually prefere it on track. Anyway put all original rings on and it still doesn't work, no problem though.
Thing is everytime I bleed it air gets locked in the abs pump and I need to plug it into Renault clip or similar to prime the pump clean, having a track car I can't bleed without paying for diagnostics is a royal pain in the arse. I know most will suggest a 172 cup setup but this is proving difficult to source!
So my idea: Ph1 master cylinder with the 4 individual outlets directly attached to the four delivery pipes which originally come out of the abs pump, therefore bypassing it. Okay a few questions for people with the knowledge.
1) does the abs pump control the front/rear bias or is there a mechanical backup?
2) will it affect pedal effort or travel adversely?
3) is there an easier way to do this?
Help me out people, thanks!
