ABS Fault - Boing Noise
  Clio 172 Ph1
I have a 172 ph1 track car.
I'm getting a "boing" noise from the ABS when I come to a halt. Brakes are working fine and I'm not getting the "boing" when applying the brakes, or when in motion, just right at the end when I am almost stopped or completely stopped.
Was on track day on Friday and was breaking heavilly and ABS wasn't kicking in, hopefully becuase I was just above the threshold, then late in the afternoon, with the same pedal pressure it was juddering like mad as it does when it kicks in.
I have had a look at all the ABS rings on the wheels and they all look in good condition, no damage or serious corrosion or heavy rust etc.
I am not getting any ABS light or any other lights on dashboard. I am gonna replace the front offside sensor cable as a precuation as the outer casing is a bit damaged. The others all look good and no damage at all.
The car is lowered on Leda's.
Dont have an OBD11 reader to check codes
Any ideas ?
