ph1 172
Symptoms are ABS kicks in under 'heavy' baking at junctions etc. and ABS light is on dash.
I'm guessing ABS sensor. I've had it plugged into an RS Tuner which isn't showing any faults. I've had the wheels off and inspected sensors/wires for breaks etc.
Is there an easy way of eliminating potential faulty sensors?
Also are front and rear sensors the same? I'm thinking of buying a cheap working second hand sensor to try and eliminate it that way.
On a ph1 172 btw.
On a ph1 172 btw.
