SLK 350
Right came back from work earlier and the car was fine. Just drove over to a friends and on starting the car the SERV light is on and the ABS (far left) and ESP/Traction light is also on.
The only reasoning i can think of is that the rear pads needs replacing (which i am planning on this week) however there is still a few .mm of pad left on the liner - therefore am not sure if this would trigger the fault.
See what feedback i get from your guys, but failing that ill disconnect the +ve on the battery to reset the ECU into 'learning mode' and see if that stops the fault.
However, any ideas?
Cheers.
However, any ideas?
Cheers.
