Hi,
I am having more nightmares with my wife's clio sport 172.
I am getting a real juddering and feedback from the brake pedal on a clio 172 (non cup). I have replaced the discs and the pads but forgot to check the abs ring!
Am very annoyed with myself but I have had real distraction as I had a wheel stud snap off in a hub (thanks tyre fitters who must have over tightened!). Got a 2nd hub and fitted yesterday, car has been off the road for about 4/5 weeks.
Took me ages to get the hub off the driver side everything was seized solid even the brake piston was a pain to get on that side. Wheel studs back on torqued to 90nm.
Anyway I am guessing the brake judder is due to a cracked abs ring, I suspect the passenger side. From what I can read you can knock the old abs ring off the drive shaft but I can't find anywhere that sells the abs ring and I just wanted to check how many teeth the ring has is it 44?
Where can I buy a new abs ring? And is it easy to do????
I'll also have to get a new ball joint splitter as fitting the new hub broke my other one...
The joys of owning a clio...
Thanks for replies from a fed up husband of a clio sport driver
Richard
Richard
