ABS Sensor Bracket Bolts (Part No Help)
Ricardos
  LY 200 EDC
I've bought new brackets that hold the ABS lines from Renault which bolt to the front dampers. The problem the parts department have is finding the part number for the Torx screw that holds this bracket to the damper.
Has anyone bought these and have the part number on an invoice they could post on here??
I've been to the breakers and the Clios i've tried to take them off are rounded off or too rusty to get the 30 torx bit in. Failing that does anyone have a couple they could sell to me :eek:
Apologies if this is in the wrong section
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
IIRC its nothing more than a 10mm M6x1.5 Hex - they won't be able to sell you a single item as they come to them in packs of 30. You'd be far better off going to either a local fixings place or even a DIY store such as B&Q, Focus, Etc and buying what you need from the hardware sections.
