ABS Type Question
ive been reading through alot of the threads on here relating to 172 abs etc..........am i right in saying - 172 Rear, ABS ring is on the disk?, and 172 Front, ABS is in the hub, or is that on the disk also?
If its in the hub on the front^ whats the difference between it and the ABS in a 1.2 hub....different amount of teeth like the rear? If so, is the ring interchangable?
cheers.
regarding the wanted thread.........putting 172 running gear on and run it with the 1.2 until i have the facilities to drop a 172 engine in, but planning to keep abs.....
  Lionel Richie
good luck keeping the abs! sod off the 172 running gear and use the 1.2 stuff, you will have to change the front bodywork also if you go for 172 running gear
yeah thought as much, butttt with enough camber its possible to get away with it isnt it? 172 hubs/track width etc on matt's TT with std wings?
