Abused 1.2 8v MOT test results
You might remember my post about our families incredibly abused mk2 ph1 1.2 8v. Apparantley the car should be fucked etc etc
Anyway took it for an MOT today and it passed 1st time as usual. Thought i'd put the emissions up as its interesting they're very low.
RESULT DIAGNOSIS LIMITS
min max
Fast Idle Test PASS
Engine Speed =2500rpm PASS 2500 3000
CO Level at 2800rpm =0.00% PASS 0.20
HC Level at 2800rpm =12ppm PASS 200
Lambda at 2800rpm =1.01 PASS 0.97 1.03
Natrual Idle Test PASS
Engine Speed =757rpm PASS 450 1500
CO Level at 757rpm =0.00% PASS 0.30
OVERALL RESULT EXHAUST EMISSIONS TEST PASS
Is that normal? My valver just scraped through on all of those but the 1.2 is perfect.
Matt
It can be, my old Williams was treated hard all its life and has cams etc on it and it passed with very similar results I think the CAT did its job.
iv jus had a willy 1 for an mot. it failed miserably on emissions last time...due to fukt lambda.
results were.
min max
Fast Idle Test PASS
CO Level at 2800rpm =0.10% PASS 0.20
HC Level at 2800rpm =17ppm PASS 200
Engine Speed =---rpm PASS 450 1500
CO Level =0.14% PASS 0.30
guy doin the test said it was bang on.. but there will be variations between the allowances for both engines i would have thought
