AC Evaporator Overflow Pipe - 2005 182
Hoping this is a quick one... I have done some searching but I can't find the answer.
I am looking for where the Evaporator overflow pipe (the one that causes the puddles of water in hot weather) as now the AC is fixed I just want to check the pipe isn't blocked as I really don't fancy having a paddling pool in the car, but I can't seem to locate it!
Anyone know?
Rich
  172 Ph1
It drains from the box in the drivers side scuttle panel area , and leaks down to the right scuttle drain / drivers wing / arch liner.
Depending on angle will also drain out the centre drain tube from the scuttle
