Accelerator delay at 60mph and above
  Renault Clio 1.2
Hi
I am new to the forum and am posting in the hope that someone can help me with my problem.
My problem is that when my car is going around 60mph and above, I try to give it more power and it will stick at the same speed for a second or two and then finally move forward.
I took it to a garage where they plugged It in and found the following fault codes:
DF095:Brake switch information
DF057: Upstream 02 sensor circuit
DF064:Vehicle speed signal error.
They removed the throttle body and cleaned it out and re-fitted and cleared the fault codes.
They said it was fine but I then drove another large motorway stretch and problem persisted.
I have then took it to a different garage who when taking the car out, had no problem.
I then got car back today and problem still persist.
Would appreciate any help and confirm that no hazard warning light has come on during this at all
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
It sounds like an H02 fault but ideally it needs to be looked at properly to see whats happening (or not) when you press the loud pedal.
Some places don't actually have a clue and just want your money. Others are more interested in actually helping you so do your homework next time before putting your car in for work.
