Accustic valve
Piss easy mate.
Remove the front bumper, unplug the acoustic valve from the plug, (that can be cable tied away) and remove the air pipe. This can be cut down but it needs to be plugged up with a bolt or something as itll create a air leak. I cut mine down, fed it through the engine hoist cradle and bolted it that way. Im sure the acoustic valve is connected to the horn bracket.
Ah sounds straight forward I'll give it ago!
If you don't fancy removing the bumper you can also get to it by removing the nearside front wheel and arch liner
