Acoustic(sp) valve
Have searched but have a very quick question re the pipe that comes from near the inlet, the one circled below.
Can i just block this off now as im not using the acoustic valve?
thanks
Yes. You should have done that when you removed the valve. :)
You can either block it at the manifold (and remove the pipe) or else simply plug the open end down where the acoustic valve was fitted.
