Acoustic valve noise ?? Help
Car  182 Cup & 172
Hi guys need some help, ive removed my acoustic valve and replaced it with a straight through cold air feed pipe, but when i started the engine i could hear a hissing noise coming from one of the small pipes which i unattached from the acoustic valve, is this gonna be a problem ? Should i plug it etc...
cut the pipe close to the plenum and put the end of a biro in it to plug the hole. Tried and tested :D
