quite a few threads mate on this if you do a search.
basically jack front nearside up, remove wheel, follow the pipe from your airbox down and you will see the valve plumbed into it, undo the bolt that holds it in next to the horn, disconnect the electric connection and tie it up safe and the small silicone tube plug it with a screw.
much better guides on here though via search button.
