If you take out the near side arch liner you'll see the acoustic valve on the same bracket as the horn. Unplug everything, and then you have to block up one of the tubes with a bolt. There is a guide somewhere, ill find it for you.
Cheers mate I've printed out that guide, will try and do that this weekend. I've seen it before but did'nt know what was it's purpose, because my induction kit is already disconnected from it, so I'll probably just take it out to make room for a CAF, if I removed it and block of that pipe, will it do anything to the normal running of the car?
no hassle to remove at all if you follw the guide on here. if you remove the frontg fogs too, you will get more air circulating its way to the airbox. remove the top airbox feed too.
ooohh just read that bit about bunging something up.. my clios idle'd at 1100rpm for ages never seen it as a problem might look into this after ive done all the other jobs i need to do on the car lol.
