TC.
		Right so as some of you may know my engine sh1t itself and left me needing new valves, belts, gasket etc with a dose of skimming through in for good measure. Now im not mechanically minded if something goes wrong its sent to the mechanic, i pay the bill and all is well but im a bit p1ssed and suspicious at this one.
2-3 weeks after getting it back from the mechanics the engine managment light comes on and the engine sounds like its about to blow up. I pull into a garage and it turns out theres fcuk all oil in the car so I ring the mechanic "it sounds like its burning oil get it up and il have a look" so it gets sent back up and he reports theres no oil leaks or burning that he can see and that its running on 3 cylinders, he changed the plugs and said if the oil levels go down as quick again its a broken piston ring !
Now im pretty sure valves tie in with pistons in some way so Im thinkin hes fucked up the work and this is a result but no hes claiming its the bottom end this time and absolutly nothing to do with his work !!!
I feel like im being had big time here, he could tell me any old rubbish and who am I to argue something I know nothing about.
What does this sound like to you ? Advice needed
