you can get 15"/16"/17"s for your 1.2 no problem. No rubbing etc, unless you slam the suspension
would -40mm be ok??
buy mine in the FS section.. all problems solved lol
I had 40mm drop on 17"s no problem.
then I had 17"s on coilover suspension 70mm front 80mm rear, but i took the arch liners out in the front..
Thanks!you can get 15"/16"/17"s for your 1.2 no problem. No rubbing etc, unless you slam the suspension
I was actually looking at those earlier, bit too 'girly' for me. I'm actually after some black ones though, not sure what style/model/make or anything yet.buy mine in the FS section.. all problems solved lol
I would only get 15's if i were doing a euro theme
16's for handling
17's for looks
All will fit nicely though without rubbing
