Aerial Signal Booster
those are the signal seperation filters are they not ?
ive been told that they wouldnt work and simply filter out the fuzzy channels rather than actually boosting the signal
Its been a while since I had to use them but Ithought it helped boost the reception. I know that you have to connect it up to the rem wire when installing. Try ringing autoleads tomorrow and ask them to make sure (I assume you have the number at motorworld!)
£9.99 for the signal seperation filter, and yea it says on the instructions......
however, ive rang Autoleads before about this and been told 2 different things, once got told they ARE a signal booster, and then got told by a diff person on a diff occasion they arent, they simply filter out the crap channels
i tried one in a Ford galaxy of a customers the other day and it did f**k all.......
oh shoot, forgot to reply :oops:
basically signal boosters dont really boost the signal, they just filter out the part you dont want to hear, aside from buynig a new head unit/aerial/re-wiring it all you will just have to put up with it im afraid
(all above in my experience, thats not to say its different for someone else)
arse, i thought that might be the case..........
anyone know if you can buy an amplified aerial with a small mounting hole requirement
