After some suspension settings
Car  Dodgy one
With anyluck i should have some Coilies on my clio on Monday and will be taking it into work to be tracked up,
With regards to camber and toe what should it be set at?
95% of the time my car will be on the road that means it'l probrably never end up on track apart from a drag strip lol. I dont drive it like a looney but would like it to hold the road well and not ruin my tyres
Rich
Ok I'm thinking about -1.5 deg Camber on the front, Dont want more TBH i dont push it too much
having the toe set at 0 (poss toe in very very slightly) as it does 50/50 motorway
and the rears fixed isnt it unless i shim it which i wont be doing?
With any luck that wont eat my tyres will it as in they should wear pretty even, Correct?
correct, remember suspension settings are a very personal thing, what suits you might not suit me etc
camber at around -1 to -1.5 will be fine on a road car, toe its up to you
Thanks Fred, Am i right in thinking they are the same as the factory settings for 182cups apart from i think they run -1deg camber instead.
I'm happy with it now on Sportlines, Turns in well but feels a bit light when traveling along at 80 or so on the motorway therefore I suspect its toeing out at the minute,
